- Machine Type:
- Laser / Plasma
- OpenBuilds CAM / OpenBuilds CONTROL/ SketchUp
- Electronics:
- OpenBuilds BlackBox
- Machine Time:
- 2-3 min
- 1mm
- Feeds & Speeds:
- 2700 mm/min
- 16GA Steel (1.5mm)
W r e n c h G u yThis was a fun little project to make as a first cut on the LEAD 1010 PLASMA Cutter Add-On
P l a s m a P r o j e c t
Its become the Hello World in OpenBuilds CAM example files for the plasmas first cut
It's called wrench guy and it cuts out flat with a couple notches that you line up on the edge of a table and bend into position. Its so thin at 16 gauge that its easy to bend and form.
1st bend that is closest in on the design is 90 degree an the second bend that is the farthest to the outside is about a 60 degree bend so that its enough to hold onto what ever you choose to hook on or lay across the tabs.
