Coined by my family as the: Davomatic
Discussion in '3D printers' started by JerwanDavis, Aug 12, 2018.
  1. JerwanDavis
    JerwanDavis published a new build:
  2. JustinTime
    Jerwan, why do you need two steppers for the z axis if it's going up and down only on one side what with it being cantilevered?
  3. JerwanDavis
    I don't have 2 steppers on the Z axis, I only have one.
  4. JerwanDavis
    Sorry, I reposted... :) I am inly using 4 Nema17 motors for the entire build. I must have made a typo on the original post.
  5. Mysterious_Wanderer
    I find this very interesting because it's the only 300x300 or bigger cantilevered printer I've ever seen. I am interested in converting my CR-10 into something similar (there's quite a few reasons why but it would mostly be as an experiment). Where exactly are you experiencing the vibrations; what axis are coming out of alignment? Is the z gantry drooping, the x rail swinging side-to-side, or both?
  6. Hiteshkumar Patel
    Hello
    im verymuch thankful to you for sharing this projects i like to develop same projects can you share drawing file so i can understand some cable and motor and other things you jointed and which thingiverse files you used please post here or can you sent me on [email protected]
    thanking you
    Hitesh Patel (India)
