Routing DXF Image
Discussion in 'CNC Projects' started by JoelW, Oct 23, 2020.
Tags:
  1. JoelW
    JoelW New
    I want to just route around the perimeter of a DXF image. I am using Fusion 360 and when I try to do a 2D contour around the image the bit does not carve into the wood. I realize that I need to tell Fusion how deep to go but haven't found where I would put that setting.
    Thanks,
    Joel
  2. sharmstr
    Set the stock to leave to a negative number. Its in the passes tab.
    Edit: Axial stock is what you set, not radial.
  3. JoelW
    JoelW New
    Thanks Shawn, That did the trick
