      First and foremost, this is a GREAT machine out of the box. Granted, it could be a little easier to put together but I believe that is a benefit since you know EXACTLY where to go and what to do should something go wrong. The base design is very good for 99% of the people using these machines but I tend to land in the 1% when it comes to my tools so here we are.
      Goals for this build:
      1: Raise X axis to allow thicker parts to be machined
      2: Eliminate slop and flex
      3: Increase serviceability should I need to tighten, replace or modify anything in the future
      4: Get rid of all of the SOFT bolts that I could supplied in the original kit
      After looking at probably 100 different modified "Hobby" CnC machine mods, I found quite a bit of really good information here on the OpenBuilds forums. This build borrows heavily from Jacob Lotter's 1510 modified build (1510 Workbee Modified)
      Since I don't have a machine shop at my disposal, I had to get creative making the brackets. I DO have some metal cutting saws and drill presses so that helped immensely. Bottom line, if you're 1/2 way equipped and somewhat handy with tools, you CAN preform these mods.
      Parts List:
      4 - 15-1500mm 2x Linear Guideway Rail 4x Square Type Bearing Block HGH 15CA (HiWin Clones on ebay)
      2 - Blue Ox Deluxe WorkBee Taller Y Side Plates by chrisclub1 on ebay (2" taller, 1 pair)
      100 - M4 T-Slot Hammer Head Nut, 2020 Series Silver Carbon Steel Fastener Aluminum Profile Extrusion Slot
      100 - M5 T-Slot Hammer Head Nut, 2020 Series Silver Carbon Steel Fastener Aluminum Profile Extrusion Slot
      200 - M4-0.7 x 15 MM Metric Allen Socket Head Cap Screws Grade/Class 12.9 Alloy Bolts Black Oxide
      100 - M5-0.8 x 15 MM Metric Allen Socket Head Cap Screws Grade/Class 12.9 Alloy Bolts Black Oxide
      4' - 2"x2"x1/4" aluminum 90 degree angle "iron" from OnLineMetals.com
      3' - 1 1/2"x1 1/2"x 1/8" aluminum 90 degree angle "iron" from Home Depot
      1 - Openbuilds Z axis with linear bearings from CnC4NewBie with drop plate
      Picture Explanation:
      IMG_3858 - Y Axis rail mounting bracket with stock sideplates.
      IMG_3859 - Y Axis rail mounting bracket with stock sideplates view 2. Note, you cannot put screws under the X axis as they hit the extrusion
      IMG_3863 - Y Axis rail mounting bracket with BlueOx sideplates. All screws in place
      IMG_3864 - End picture of BlueOx sideplates. Most all of the bolts have been replaced. Also painted the side plate because that was a LOT of aluminum staring at you.
      IMG_3865 - X Axis gantry. I had to retain this piece for the lead screw. It also gives me someplace to fasten all of the wiring
      IMG_3866 - X Axis gantry brackets. There isn't a lot of load on the rear plate so I could get away with thinner metal back there.
      IMG_3867 - CnC4Newbie Z axis. This thing is a TANK!
      IMG_3868 - The biggest problem I had with the factory Z Axis was it worked loose and was almost impossible to tighten. I redesigned the factory mounting bracket and it now attaches from the front. I can remove the Z Axis in literally less than a minute now.
      IMG_3869 - Close up of gantry brackets. You need to cut a 1/2" off one side to clear the factory rail.
      Takeaways/Lessons Learned
      Get more metal than you think you'll need, especially if you haven't discovered Jacob's engineering drawings on his files page yet.
      Once you place the Y and X axis rails, tighten ONE bolt at one end on each side (or top and bottom) and leave the rest of the rails loose. Cycle the axis back and forth a few times to let everything move around a little and seat itself. I then cycled by 10mm and snugged the bolts down as I went. I'm sure I affected my accuracy by an extremely slim margin but I'm not machining for NASA so I believe I'm good.
      The cable chains do pop open and WILL slide out through the holes in the X/Y end plates
      If you install taller end plates AND a new Z axis, you WILL need the drop plate for the Z axis. I now have right at 5" of clearance between my waste board and the bottom of the Z axis.
      Mathieu at CnC4Newbie is great to work with. Very responsive to e-mail and their product is built like a tank. Highly recommend these guys!
      I'm sure this isn't the only build like this but I submitted so I could hopefully give someone another resource to use in their quest for a stiffer, faster, more accurate machine.
      graveur, Xlcacer, sharmstr and 3 others like this.
    Jacob Lotter 1510 Workbee Modified
