OpenBuilds WorkBee 1510 Machine Parts Bundle please click here.
60"x40"(1500x1000mm) Belt Driven
Hello Everyone!
The OpenBuilds WorkBee Machine is based on the
WorkBee CNC Machine by OpenBuilds Member, Ryan Lock.
We have been working with the WorkBee here in the OpenBuilds lab for some time now. It's a super strong, accurate and easy to assemble CNC machine. It gains its strength by incorporating a combination of C-Beam Linear Rail with multiple uses of the full size Xtreme Solid V wheels! It’s a great machine and we're sure you will love it!
Ooznest.co.uk – Ryan Lock’s UK Based company where you can find the Ooznest WorkBee Kit and many other great OpenBuilds Parts.
Thanks goes out to Ryan for creating and sharing this awesome open source design as well as all contributors who help to spark and create new ideas here on OpenBuilds and throughout the open source community. You guys rock.
The OpenBuilds WorkBee is available in three sizes.OpenBuilds WorkBee 1510 Specs:
- The OpenBuilds WorkBee 1510 has a footprint of about 60" (1500mm) x 40" (1000mm) and is a belt driven machine with the exception of the Z axis being lead screw driven
- The OpenBuilds WorkBee 1010 has a footprint of about 40" (1000mm) x 40" (500mm) and is a lead screw driven machine.
- The OpenBuilds WorkBee 1050 has a footprint of about 40" (1000mm) x 20" (500mm) and is a lead screw machine.
MDF Spoiler Board Size:
- Woods Hard/Soft
- Plastics
- Aluminum
- Foams
- much more...
H 3/4" (19mm) W 33-1/4" (855mm) L 59" (1500mm)
Assembly time: Can be assembled in about 4 hr ~ or in about an afternoon.
* Build Video Link Sections
Video Build of the OpenBuilds WorkBee 1510
Jump in and when you complete this easy and fun step by step build-along video you will have an awesome 3 Axis CNC router for your garage or work shop.
Y Axis
X Axis
Z Axis
Frame
Spoiler Board
Wiring Build Video of the OpenBuilds WorkBee 1510
Grab your OpenBuildsCAM,OpenBuildsCONTROL software, and WorkBee 1510
here
Dewalt Router Installation Video
Note: The all new RoutER11 kit has replaced the Dewalt. Set up is the same as the dewalt. The kit includes all you need.
Grab your RoutER11 kit here
Control Board
Software Work Flow:
Mods and Upgrades
- We use the free SketchUp Make for our CAD (makes the 3D model parts)
- For creating 2D drawings we use the Free and Awesome OpenBuilds CAM
(CAM Works up the cut lines and makes the GCODE for the parts)- For controlling the machine we use OpenBuilds CONTROL Software
(CONTROL Reads the gcode created in cam and moves the machine to make the part or art)
Hey guys, the community has found these tricks and tips that are very helpful when building your 1510 belt driven WorkBee. Please take time to check them out.
- Make sure that all timing pulleys are tightened down completely to the motor shaft of all axis's. (You really want the pulley and motor shaft to be one.) NOTE: You can also use M3 x 6mm screws in place of the grub screws.
- Add zip ties to all ends of the belt overlaps once tension is properly accessed to the belt. (This will insure that the belt cannot come loose in time)
- M5 x 12mm screws are provided for the belt tensioning process, so it's easier to add tension to your belt drive system.
- #8 ½” wood screws work great for the mounting of the spoiler board.
MISC.
Machine profiles is included in the OpenBuilds CONTROL software
Gallery
- OPEN SOURCE - This machine is Open Source and the Builder community is encouraged to modify and build on this design.
- For your convenience and ease of purchase this Build is available as a Parts Bundle -
OpenBuilds Workbee 1510 (60" x 40")
Build in 'CNC ROUTER' published by Mark Carew, Dec 21, 2021.
The OpenBuilds WorkBee 1510 - 1500x1000 Belt Driven CNC Machine
Props go out to OpenBuilds Member Ryan Lock as well as OpenBuilds Team member Matt who worked up these great build log videos. The entire OpenBuilds Community is to be thanked for all the great collaborative ideas that makes builds like this possible.
Sanderlt, Dennis Wilson, Rongsok and 9 others like this. -
The WorkBee is a great example of what can be done with the OpenBuilds system. So we worked in some changes for production and are happy to make it available to community.Inspired by
The original Ooznest WorkBee by Ryan Lock -
