INTERFACE CNC Touch ControllerOpenBuilds INTERFACE Features
The INTERFACE is a powerful plug and play cnc touch control pendant system for your CNC machine
Its never been easier, simply load the job, set the starting point and run it.
Interface was designed as a purpose built tool that is a part of your machine. It is rugged, user friendly and it will quickly become a favorite in your shop!
Interface puts control in your hands, enabling you to jog, home, zero, load and run jobs all from a stand alone plug and play hand held pendant.
No computer required! Run your jobs directly at your machine with the Interface
Get your INTERFACE CNC TOUCH CONTROLER here
- Standalone Human-Machine Interface for controlling your OpenBuilds BlackBox / Grbl based CNC machine
- No computer required: Plug in a flashdrive with your G-Code files and run directly from the Interface
- 240Mhz 32-bit Xtensa Dual-Core Microprocessor
- Supports FAT32 Flash Drives
- Color TFT LCD display
- Capacitive Touch buttons, with tactile and audible feedback
- Supports Homing, Jogging, Probing, Zeroing and Running your CNC machine
- Plug-and-play with OpenBuilds BlackBox motion controller
- Can be used with any Grbl 1.1 based controller, which has RX/TX/GND/5V pins (may require you to make your own cabling)
OpenBuilds INTERFACE Specifications
Gallery:
- Plug and Play easy connections for OpenBuilds BlackBox
- 520Kb SRAM
- 4Mb Flash
- 802.11 b/g/n Wifi (Firmware upgrades)
- Bluetooth v4.2 and BLE
- High Contrast Color TFT LCD display
- LED Backlit Capacitive Touch buttons
- Beeper
- Vibration Motor
- USB-C Connectivity
- Grbl 1.1f and newer Support
- FAT32 Flash Drive Support
INTERFACE CNC Touch Control System
Build in 'Circuit - Software Project' published by OpenBuilds, Dec 16, 2020.
Super cool standalone Human-Machine Interface for controlling your CNC machines!
Smcfarrell, Psadave46, Darriel Fisher and 3 others like this. -
To allow for a stand alone controller at the front of the machinesInspired by
BlackBox Controller -
Qty Part Name Part Link Comments 1 INTERFACE CNC Touch Controller https://openbuildspartstore.com/interface/ Link CNC TOUCH CONTROLLER -
