Router / plasma cutting table ( Rack and pinion )
Discussion in 'CNC Mills/Routers' started by mytechno3d, Nov 1, 2019.
  1. mytechno3d
    mytechno3d Veteran
  2. PanZlty
    PanZlty New
    Great work! What is the size of aluminum profiles?
  3. Mark Carew
    Its all good :) there are times where the process just needs a more heavy duty machine. In fact what the community does here everyday using the OpenBuilds System is amazing and inspiring. Its that challenge the pushes us to innovate using the tools we have which as we know can lead to great new ideas! This is an awesome build brother and one to be proud of for sure. It will have no problem getting the job done. Makes me want to get out there and get to work on the plasma. Thanks for staking time to share :thumbsup:
  4. Ozndmrcn
    Ozndmrcn New
    Can we have build plans and drawings for plasma table?
  5. mytechno3d
    mytechno3d Veteran
    Hello
    This build is a mix of various projects .
    The frame came from here : https://robocnc.nl/?page_id=5300
    i made some modifications to fit to my needs ( specially to adapt a rack and pinion drive and for the Z axis specially created for a plasma floating head ).
    If you need more informations about specific parts just ask me and i will try to answer you.
  6. jlipavsky79
    What kind of control system are you using?
  7. mytechno3d
    mytechno3d Veteran
    Hello , i'm using myplasm cnc controller from proma electronika.
