How does the OpenBuilds site work?
Discussion in 'OpenBuilds Forum Help' started by Mark Carew, Aug 5, 2013.
  1. Mark Carew
    Check this help page first to see if you can find help learning about the way OpenBuilds.com site works.
    http://www.openbuilds.com/help/
    If you still need help please post away and we will do our best to help.
  2. Makerwill
    Makerwill New
    In case you are not aware, the link posted at the time of this reply provides an error message "The requested page could not be found.".
  3. Mark Carew
    Public Do Omens likes this.
  4. Robert E. Nee
    Hi, I started a "build in progress". Apparently I have to "publish" the "build in progress' to make incremental progress visible to the rest of the community. Is this correct? Thanks.
  5. MaryD
    MaryD OpenBuilds Team
    Yes, the build will stay in draft until you decide to "publish" to the site. You can publish as "in progress" then later update to "complete". Hope this helps!
  6. Jim Robinson
    OK so this forum has me feeling like a newbie. I can (obviously) post comments/replies but I can't for the life of me figure out how to start a new thread or ask a question? Am I missing something obvious??
  7. Rick 2.0
    Simple, go to the forum of choice (in your case I'm guessing its Laser Cutters) and up in the right hand corner you should see a blue box labeled "Post New Thread".
    MaryD and Peter Van Der Walt like this.
  8. MusaedQ8
    MusaedQ8 New
    Trying to post thread but its show me:
    The following error occurred:
    Your content can not be submitted. This is likely because your content is spam-like or contains inappropriate elements. Please change your content or try again later. If you still have problems, please contact an administrator.
    change my content Same result
  9. Peter Van Der Walt
    Hi @MusaedQ8 - we've addressed an error in the configuration, and your post will now be allowed:
    I've salved the text for you to avoid retyping:
    Unfortunately the 0-10v circuitry is on the Brains board, it consists of Opamp circuit to change the 5v PWM circuit into a 0-10v circuit. You can look at that section of the schematic on the PDF schematics on the files and drawings tab of BlackBox Motion Control System
  10. nls
    nls New
    I am getting the same error trying to post my first thread.
  11. Peter Van Der Walt
    Something in your content is triggering automated spam prevention, or your Browser has some script/adblock plugin preventing proper functioning
    Try a clean install of Edge/Chrome/Firefox
  12. nls
    nls New
    Thank you.
    I am using Safari, but it must have something to do with the content as Chrome and Firefox give the same error.
    Will try to rephrase, but actually do not have a clue what could have triggered the spam filter.
    #12 nls, Feb 22, 2022
  13. nls
    nls New
    I'm sure I'm making terrible language mistakes, but that's not the function of a spam filter... is it?:)
    So not to ask my question about a problem with my spindle here, but what in the attached draft text triggers the spam filter?
  14. Peter Van Der Walt
    With $31 set to 4000 offsets the scale - rather leave that on $31=0 (So M3S0 = 0v)
    As is any S value from 1-4000 = 0.02v (0.04v on 0-10v) will effectively be M3S4000, except now the scale is changed too (4000-25000 maps as 0-25000). See Grbl v1.1 Configuration · gnea/grbl Wiki and Grbl v1.1 Configuration · gnea/grbl Wiki
    Regarding M5 not stopping it, please check in with the Mafell vendor for advice, not sure what that could be - one would assume there 0-10v input honors 0v=stop.
  15. nls
    nls New
    Thanks again.
    It seems 0V = 4000 RPM is function, not an error. I've misread this before, so thanks for drawing my attention in the right direction.
