C_Beam X5L Hybrid_Tank
Discussion in 'CNC Mills/Routers' started by HC.Carbo, Feb 26, 2018.
  1. HC.Carbo
    HC.Carbo Journeyman
    Leobiker299 likes this.
  2. MStillman1966
    looks like its getting complicated now
  3. MStillman1966
    what are going to make ??
    what is your vision (of the product) that you are making that machine for??
  4. HC.Carbo
    HC.Carbo Journeyman
    aim is to make few of my 3d printed figures in wood (not a big fan of pla)
    HC.Carbo
  5. MStillman1966
    very cool stuff!!
  6. HC.Carbo
    HC.Carbo Journeyman
    was missing 1 driver, most of the pic's online where for 2 stepper in the opposite direction.
    this was working for me
    have 6 drivers now, but was running into another issue...homing :)
  7. Mark Carew
    @HC.Carbo Great build man! Can't wait to see this one in action. Its really going to be cool to watch it create some of your art. Looking forward to seeing some of your projects as you learn to use this mad machine :D
    kram242 ;)
  8. HC.Carbo
    HC.Carbo Journeyman
    he he 242 :D
    grts from Belgium....but you know...it never stop's :D
    Batcrave and Mark Carew like this.
  9. HC.Carbo
    HC.Carbo Journeyman
    hope to cut these :)
    ok nothing beats the steel ones... but way to expensive.
    only suited for DM fans :D
    GrayUK likes this.
  10. HC.Carbo
    HC.Carbo Journeyman
    ok, reality check today.
    cool, everything works well & smooth
    but, :)
    not a good idea to place the a/b table in the length (not practical, you can't see what is going on)
    So, seems i have to modify a little. The table don't fit in the other direction (need+ 2cm more in the y)
  11. Mark Carew
    true true :thumbsup:
    What about a 90 degree bracket system that has the ab table mounted to it and that can be mounted to the spoiler board of the machine so you can remove it when you want to use it as a standard 3 axis mill? Just a thought but it may also block the view as well.
    HC.Carbo likes this.
  12. HC.Carbo
    HC.Carbo Journeyman
    much better now & a/b table is also fixed on the sides (1 min. to remove :) )
    z=15cm (still have 8cm left on the gantry)
    GrayUK and Mark Carew like this.
  13. Mark Carew
    This is going to be cool! :D
  14. HC.Carbo
    HC.Carbo Journeyman
    yeah...it cut's allu....to say it cut a part out of my A/B table :D
    reality check 2,
    Hardware wise everything ok (hence static electricity seems to be an issue)
    software, mmm setup vertical no go > it cut's only 2 sides (guess the post is for horizontal) but easy to work around.
    3 attempts to make a video today, but... my gopro crashed & then my laptop crashed & @ a last attempt my A table seems to turn the wrong side.. :D :D :D
    multi axis: mmm not sure, seems it doesn't work on spherical shapes...
    here my test setup, little dog cut out of a champagne cork :)
    video next week...hopefully :D
    Cheers! :D
  15. HC.Carbo
    HC.Carbo Journeyman
    after 4 attempts...you can see +- a dog :D
    rough adaptive, **** hard to zero all on the right spot. (y a little off)
    done in one run
    GrayUK, Scotty Orr and Giarc like this.
  16. Giarc
    That is awesome!
  17. Scotty Orr
    Scotty Orr Journeyman
    Yeah - what he said!! :thumbsup:
  18. JustinTime
    JustinTime Veteran
    very cool indeed! :thumbsup:
  19. HC.Carbo
    HC.Carbo Journeyman
    bang my head...just cut out the Austere Bunny, but it went wrong at the last cut. (z gantry touched the a table) grrr :)
    Learn every week a little more :)
    just have to set the b 45° :D
    Paul Stoller and GrayUK like this.
  20. HC.Carbo
    HC.Carbo Journeyman
    Little late, (no it wasn't the machine) :)
    indexing a bunny
    few flaws, but the ears are still on it :D
  21. GrayUK
    It's certainly getting there!! :thumbsup::thumbsup: I don't think cork is the best material to work on, it won't give a clean finish, which I think you could get with another material.
    What about a small block of some kind of plastic? What size cutter were you using?
    I think you've done a great job so far. :thumbsup::thumbsup::thumbsup: I am so impressed with this build. :nailbite:
    Well Done :D
  22. HC.Carbo
    HC.Carbo Journeyman
    3mm mill (Chinese :D ) , soft mat. good for testing. (2 little flaws in the toolpath) :)
    still have to order some descent mills
    (avoid to do a tool change, often it loose connection when touching the machine)
  23. GrayUK
    I'LL BE WAITING FOR YOUR NEXT VIDEO :D
  24. HC.Carbo
    HC.Carbo Journeyman
    Have already a soundtrack for it...now the footage :)
    GrayUK likes this.
  25. Mark Carew
    Awesome video @HC.Carbo its so exciting to see this machine coming to life, keep up the great work
    The important bit! :thumbsup:
  26. HC.Carbo
    HC.Carbo Journeyman
    Finally some wood, but... things went wrong :D
    @ other hand, seems the simultaneous multi axis is working fine now.
    Wanted to redo the flow (& cut some more stock of)
    when i started @ the same (new) g-code line it went wrong somehow :)
    aim is to cut the OB logo out of it
  27. HC.Carbo
    HC.Carbo Journeyman
    only multi-axis flow (1 direction) & contour
    Sadly my center point little off
    But toolpath is good, so hopefully a nice keychain next week :)
      File size:
      107.4 KB
      437
    GrayUK likes this.
  28. HC.Carbo
    HC.Carbo Journeyman
    Peace out :)
    Finally something, flow on both sides.
    gives a nice round shape on both sides.
    James_Hopkins, Scotty Orr and GrayUK like this.
  29. Giarc
    I love this thing!
  30. GrayUK
    That is soooo cool!! :D:D
    I could watch it for hours.
    Nice One :thumbsup::thumbsup:
