Acro Pick And Place Machine
Discussion in 'Other Builds' started by Greg Wroblewski, May 13, 2018.
  1. Greg Wroblewski
    Greg Wroblewski published a new build:
  2. pek
    pek Journeyman
    Very impressive work, keep going!
  3. Mark Carew
    Agreed! this is an amazing build @Greg Wroblewski and it looks like it works very well.
  4. Moz Manolakis
    Amazing
    well done
    I am interested in building one
    where Is the software from can i load to check
  5. Greg Wroblewski
    I recommend using OpenPnP software. The one I wrote is purely experimental (gwroblew/CoolPnP). Setting up OpenPnP software should be easy, since all components are standard.
  6. Gary Caruso
    Mind blown! great job!
  7. TurfnSurf
    TurfnSurf New
    Placement speed (parts per hour?)
  8. Greg Wroblewski
    I optimized it and with triple vision steps (for accuracy), it can do 500-600 CPH. I could see it doing 1000+ on 1206 components or larger.
  9. TurfnSurf
    TurfnSurf New
    Sorry to be asking dumb questions - you need vision to pick n place 0603 components then I'm guessing? What changes do you think would have sped yours up, if you were to make it again?
  10. Greg Wroblewski
    Yes, 0805 could possibly work without vision, 0603 will not for sure. A closed-loop stepper motor could possibly help, or linear encoders for x and y.
  11. Shawn Melanson
    where do you think the inaccuracy comes from? I'm researching on how to build my own PNP and I'm not sure if I should go with the knock off hiwin linear rails or the Vslot linear rail.
