300mm Diameter, 1 Meter tall, Delta 3d Printer
Discussion in '3D printers' started by Gerald Klein, Jan 7, 2018.
  1. Gerald Klein
    Gerald Klein published a new build:
  2. Anthony Bolgar
    Anthony Bolgar Journeyman
    Nice looking printer.
  3. Gerald Klein
    Thanks !
    Was a lot of fun to build. And I learned a lot.
  4. Polymorph
    Polymorph New
    Very nice. Any chance of some close-up pictures of the completed printer? How do the prints look at the top of the print volume?
  5. Laminae
    Laminae New
    Would you be willing to share more detail, most primarily what alloy you used for you base and top and rough total cost? Any details on carriage, build volume, effector, limit sensors etc would be appreciated as well
  6. Gerald Klein
    sorry for not replying till now.. I have no problem sharing the build information.Anything you'd like to know.
    I'm on my way out right now, but This weekend I will update the post. more pics, video.... etc etc.
    I'll take some pics of the top of some of the tall Vases I made.
    #6 Gerald Klein, Jan 11, 2018
  7. Gerald Klein
    for now.....
    I had the top and bottom made out of aluminum. Total cost will be hard cause some of the motors, belts and some other parts I had already, but I will try.
    build volume is 240 Diameter ( that's what I set it for I think I can push it further... but didn't need to )
    Carriage are cbeam gantry plates
    end effector is 3d printed from my own design, will most likely have that made out of aluminum soon.
    limit sensor are optical
    hotend is a the minihotend from Deltaprintr ( not a misspelling )
  8. Gerald Klein
    New pictures uploaded !
    if you have an specific pics you want.. just ask.
    GrayUK likes this.
  9. Gerald Klein
    So I did a rough total cost... not including all the nuts and bolts, so just the main parts.. I'm around the $1100 mark.
    (That's including the overkill Bottom and Top plates which cost $350 to have water jetted, I do love the accuracy of it though !!! )
  10. Polymorph
    Polymorph New
    Thanks for the pictures, the print quality looks good.
  11. Gerald Klein
    I was surprised too.... LoL
    No.. really...it's just as good as any other delta I've seen. I Got the settings just right I guess..
  12. Polymorph
    Polymorph New
    I have most of the main parts for a similar project, with a 330mm base and 1.5m long rails. Of course, by the time everything is taken into account, I hope to have a printable height of 1m.
  13. Gerald Klein
    Wow. And I thought mine was tall... Can't wait to see it. Are you using cbeam ?
  14. Polymorph
    Polymorph New
    Maybe I should be, but I"m not. 4020 with Nema 17 and belts, linear kits from Open Builds part store. I am planning on adding some 4020 or 6020 across the bottom to stiffen.
  15. DeltaCon
    DeltaCon New
    This is a really nice build! I think the C-Beam is a little overkill, but it is very inspiring to see the bottom and top plates used like this. I've been thinking in the same direction for some time, but did not (yet) put it into practice ;-) This construction leaves very little room for dis-alignment...
  16. DeltaCon
    DeltaCon New
    Question: this piece of text from your introduction struck me: "I had the top and bottom plates water jetted, for the level of accuracy that type of cutting has.". Would you say that lasercutting is less accurate than waterjetting? I would think the opposite, but have little experience with this...
  17. Gerald Klein
    Oh .no, sorry. I wasn't comparing water VS laser. I might agree, laser would be the same or even more accurate. I was comparing having a top and bottom plate instead or more extruded aluminum parts to mount the three cbeams on, and space them appart.
    I only mentioned it at all, to say that having the top and bottom identical, is in my opinion, the first important part of this build..
  18. Chuijse
    Chuijse New
    Hi, I'm realy impressed with your design, I want to make something similar. I have been studying the tevo little monster, here is a good source of information TEVO Little monster design draft open source project by jeowin
    Why you choose such long arms ? Your design have longer arms and less bluild surface than tevo little monster, I realy interest to know the reason, because your prints have very good quality.
    How many steps/mm yo can print with this setup?
    Thx for your time! realy nice work
  19. Mark Carew
    This build is very ridged using and it shows in the print quality! Nice job @Gerald Klein :thumbsup:
  20. Gerald Klein
    First of all Thanks. Building it was a lot of work but also a lot of fun. I was pleasantly surprised with the build quality myself.
    I don't want to disappoint you, but the length of the rods ( I agree, they are a little long ) only happened because when I started ordering the parts, they were the first to show up. I was very eager to get going and so assembled them without much thought. Only to make the Identical. I realize now I could have gone shorter and have given myself a taller build height, but to be totally honest..... I've only built 3 things even near the attainable height of just over 500mm. It's nice to have, no doubt, but I realize now, in my case anyway, that a tall build height is not useful very often and that's why I haven't bothered to change it. That, and I have a strict rule.. " if it's not broken, Don't fix it !!! "
    I took a quick ( very quick ) look at the TEVO Little Monster... I love the look of it. It's gorgeous !!! I like the Dual stainless steal fan shroud, although I worry about the weight of it. and the 340mm diameter beats mine hands down. "Little" Monster.. I don't think so !!!
  21. Anthony Bolgar
    I think you mean rigid, ridged would be bad for a printer;)
  22. Gerald Klein
    I am in the process of printing out a new end effector.
    My rule, "If it's not broke, don't fix it" kicked in.
    The mini hotend from deltaprintr is awesome, but I didn't get the male end of the plugs they use and so had to cut the plugs off and solder wire directly onto it. the thermistor wires were extremely thin and my soldering job apparently didn't hold out.
    I've decided to put a 24V E3D Lite6 hotend on it. ( The heated bed is 24V )
    I modified the end effector to hold the Lite6
    I will post pics of it when completed and printing again.
  23. reahax
    reahax New
    Hi there,
    I'm gonna make a similar build. Instead of C-beam, I will use a linear rail. So for linear rail, I must use 20x60 or 40x60 profile. (dunno if 20x60 is rigid enough)
    I have 200 dia printer too, so this will be my second delta. I already have duet3d so I'm thinking smart effector+ 360mm Haydn Huntley’s Magball delta arms for this.
  24. Gerald Klein
    Linear rails are great !! As long as you get nice ones. There are definitely some "cheap knockoffs" that don't perform so well.
    As for being rigid enough, better save than sorry. LOL
    The duet3D is awesome !!! very smooth control. did you get WiFi ?
    Magball setup is great too. smooth .....
    I'm sure I will see the machine posted on openbuilds soon ! I can't wait to see the build quality with all those parts !
    I lost the delta in a house fire. And I ended up getting raise3d pro 2. not to tinker with, but it's a work horse..
    I'm now in the process of building a workbee 1010. after that is done a new delta in definitely in my future !!
  25. reahax
    reahax New
    I already have wifi edition on my small delta; I was so happy with my duet, so I ordered the second one for future :) But by mistake ordered ethernet one. It's not a big deal; I have a laptop in my workshop, at least I can upload faster lol.
  26. BigfootCowboy
    How did you secure the plates to the end of the C-beam?
