Gerber 404 Retrofit
Discussion in 'CNC Mills/Routers' started by Kenneth Martin, Apr 6, 2024.
  1. Kenneth Martin
    Kenneth Martin published a new build:
  2. Mark Carew
    Good luck with the retro fit @Kenneth Martin nice to see you bringing life back to these machines!
  3. Kenneth Martin
    Mark, in your opinion, is the BB-X32 a good fit for this machine? I saw the one build with the Laguna 4x4, which would be a similar build, but never got a response from the author. FYI, I do like the BB-X32 and it was a very good choice to get my Onefinity back running.
  4. Mark Carew
    "I will be using Nema 23 motors"
    I see no reason why it would not work for your retro fit. The HT Nema 23 have plenty of power and on a screw driven machine its unstoppable.
    Kenneth Martin likes this.
  5. Kenneth Martin
    I am gonna go this rout for the 1st one and see how I like it. At the same time start to put together a closed loop system for the second machine. The second machine has some issues with the X lead screw. I may also look into a ball screw installation vs another lead screw and anti-backlash nut. I am also exploring a rotating nut as an upgrade.
  6. Kenneth Martin
    These are the switches currently on the machines ( Aleph PS-7711) . On at both ends of each axis. Can these be used with the BB X32?
    Never been tested so cannot confirm.
