New 2 watt laser platform
Discussion in 'Laser Cutters' started by RussB, Oct 26, 2017.
  1. RussB
    RussB New
  2. Tertius
    Tertius New
    what software are you using? i want to build a 5000mm x 1000mm laser engraver with one motor for x axis and one motor for the y axis. im new here and not sure what software to use. can i use the cnc xpro v3 board for my motors and laser? will that be all that i will need regarding software?
  3. RussB
    RussB New
    I would not try to do one motor for the Y with a frame that big. You will find that the Y will NOT track straight with a single motor in frame size like that. I went with 2 Y motors and a single X motor. For the price of Nema 17 steppers, you might as well run 2 motors.
    For software I just use LaserGRBL, its free and works quite well.
    Yes you can easily use the CNC Shield for this project, that is what I am using :)
    Happy building!!!
    Cheers,
    Russ
  4. Tertius
    Tertius New
    Thanks for the reply. And one more thing where can I find a laser module?
  5. RussB
    RussB New
    Will reply in a PM as I am not sure I'm allowed to post info like that.....
  6. Rick 2.0
    Post away. About the only thing that is off limits is mystery vendors claiming to be selling "genuine" OpenBuilds parts that really aren't genuine OpenBuilds parts.
  7. RussB
    RussB New
    Still waiting on some parts to arrive.
    Since my build is relegated to the garage ;) (to quote her...' it smells like burning wood in the house') I built a fold down working platform. I also got to at least run the Y axis for a test run to check belt tensions and general alignment. 20171028_145342.jpg
    MaryD likes this.
  8. RussB
    RussB New
    Thanks Rick. Will know for next time.
    As an fyi, I purchased it through Aliexpress... but I had messaged the user a link to the one I bought.
  9. Tertius
    Tertius New
    thanks guys this is a real help. with the 1 motor y axis i want to use a stainless steal rod going to the other side with a gear for that belt. sure it will work. what is you thoughts?
  10. RussB
    RussB New
    Yes that should work. Make sure it's good and straight ;) at that distance or you may end up with induced shifting of the axis.
  11. RussB
    RussB New
    Well it's been a productive week. 98% completed now. All motors, GT2 belts and drag chains arrived. All cables sheeved and dressed. Only have the power cable to cable clamp in place.gotbto run a few test prints.... I have to say so far I'm impressed.
  12. Ariel Yahni
    Ariel Yahni OpenBuilds Team
    If you haven't tried, get LaserWeb4 a try. It works with GrBL and smoothie
  13. RussB
    RussB New
    Will give it a go.always willing to try new stuff :)
  14. RussB
    RussB New
    Some examples (Christmas presents
    ..lol) of what the build has produced this week.
    MaryD, WayTooManyHobbies and Giarc like this.
  15. RussB
    RussB New
    First upgrade on the way.... I knew it wouldnt take long.
    5.5 watt laser coming in. Nothing really wrong with the 2 watt, but hey...bigger, better, faster :p
  16. Mardonis
    Mardonis New
    Great looking build. Do you have a BOM for this project?
  17. RussB
    RussB New
    I'll put one together this weekend....
  18. Mardonis
    Mardonis New
    Thank you very much!
  19. GrayUK
    Great looking work. :thumbsup::thumbsup:
    How did you produce the "Tokamine" item? :rolleyes:
  20. RussB
    RussB New
    Grabbed the image off google and etched it through LaserGRBL :) The guitar logos are Christmas presents for relatives ;)
    Logos tend to be easy to engrave. Photos with varying grey scale are hard to get the brightness and contrast correct.
    Scotty Orr likes this.
  21. RussB
    RussB New
    BOM
    1 - Acro 1000mm x 1000mm kit OpenBuilds ACRO System
    1 - arduino UNO and CNC Shield with 4 drivers and heat sinks kit
    1 - 110/220 ac 250 watt 12 volt power supply (over kill on wattage but I had it laying around)
    3 - 1.5 meter GT2 6mm wide timing belt
    3 - 10mm x 15mm x 3m plastic drag chains
    3 - Nema 17, 2 phase, 4 wire servo motors
    3 - 14 tooth GT2 (2mm) pullies
    3 - custom made to length servo wiring harnesses
    2 - limit switches and mounts Micro Limit Switch Kit with Mounting Plate
    1 - 48" x 48" x 1/2" melamine covered particle board used as a mounting surface
    1 - 2.5 watt laser module with ttl/pwm driver www.aliexpress.com Various vendors available
  22. Mardonis
    Mardonis New
    Awesome, working on getting supplies now.
  23. dragonfire81m
    shouldn't the pulleys be 5mm bores not 2mm
  24. RussB
    RussB New
    GT2-2M Timing Pulley - 14 Tooth
    The 2mm is the pitch... sorry for the confusion...
  25. dragonfire81m
  26. melt.burn.make
    You seem to have some line gaps in a couple of your images. Is the setting for spacing too large, or is something else going on? Also, what kind of travel speeds can you get with this setup?
  27. MaryD
    MaryD OpenBuilds Team
    You should enter this as a Build in the contest! https://openbuilds.com/threads/win-the-ultimate-powerpack.11224/
