C_Beam Hammerhead 5x
Discussion in 'CNC Mills/Routers' started by HC.Carbo, Feb 22, 2018.
  1. HC.Carbo
    HC.Carbo Journeyman
  2. Sprags
    Sprags Well-Known
    I like it...my next build will be along these lines. I did programming for turbine blade manufacturing for the big jet engine and power generation manufacturing companies and this configuration is just like a few of the machines I programmed.
    Can you tell me the controller you are using for 5 axis motion?
  3. Mark Carew
    Really cool concept @HC.Carbo looking forward to seeing this one in action! Keep up the good work :thumbsup:
    Mark
  4. Sprags
    Sprags Well-Known
    I guess I should also ask if the machine is capable of 5-axis simultaneous motion?
  5. HC.Carbo
    HC.Carbo Journeyman
    yes it does 5x simultaneous (f360: swarf/flow/multi axis contour)
    little example :) need to work on my programming skills :D new to cnc
    Scotty Orr likes this.
  6. HC.Carbo
    HC.Carbo Journeyman
    a simple 8 axis motion controller with mach3/4 plugin :)
    draw back: mach4 doesn't show 5x tool path's
  7. Sprags
    Sprags Well-Known
    Can you tell us which 8 axis controller you used?
  8. GrayUK
    Excellent, Excellent, Excellent, Excellent!! Machine and Video!! :thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup::thumbsup:
    Very Well done :D:D
    Gray
    HC.Carbo likes this.
  9. HC.Carbo
    HC.Carbo Journeyman
    PoKeys57cnc& 5xPoStep60 stepper drivers.
    But not sure about the Quality, had already a bad stepper driver.
    think all boards that support mach3/4 will work
  10. Sprags
    Sprags Well-Known
    I am new to building CNC home built machines. In fact I only started on my first one a month ago.
    I have been in manufacturing and CNC programming commercially built machines for a quite a while so...
    I am hoping to build a 5-axis for a fairly reasonable cost. And in order to do that at my price point I am thinking the controller board capable of handling 5-axis of stepper or servo motor motion is in the $150 to $300 range.
    The only one I have seen that looks like it will meet my specs is this one:
    USB Mach4 CNC 3/4/6 Axis Motion Control Card Breakout Board 2MHz F CNC Engraving | eBay
    I was hoping you could tell me exactly which one you used and not just 'any 8 axis controller board' because I'm new to building and being specific will allow me to see the specs and learn what makes that specific controller board a good choice.
    As far as programming the need to understand the kinematics of the machine and then the post processor used to generation the g and m code program needs to have the geometry of the machine specified so it can output the relationships of all axis of motion correctly.
  11. Scotty Orr
    Scotty Orr Journeyman
    Awesome machine!!
  12. HC.Carbo
    HC.Carbo Journeyman
    see above answer
    here the link: PoKeys57CNC - USB and Ethernet CNC controller - Polabs
  13. Sprags
    Sprags Well-Known
    Thank you!!!!
  14. HC.Carbo
    HC.Carbo Journeyman
    so, before starting on my next & last build. A little video.
    Took one of my printed models, done a Face (to check the tool :) )
    each side a contour & a 5axis swarf on top side.
    Think the swarf is not 100% right :)
    setup in f360 & mach4 tool path
    sim:
      File size:
      333.4 KB
      336
  15. GrayUK
    Great Video, again! :thumbsup::thumbsup:
    Can't wait for a real carve! :D
    What spindle are you aiming for?
    Not something too heavy I hope, or you will have to give some thought to a Counterbalance
    on the second type shown in the video I think. :rolleyes:
  16. Sprags
    Sprags Well-Known
    Many 5-axis machines that started out as 3-axis machines have auxiliary trunnion/rotary table setups have the flat surface of the rotary table going through the centerline of the trunnion. This was to make manual programming easier back when they were used for rotation and orientation positioning. Not absolutely necessary if the post processor will allow to specify offsets in the machine kinematics.
    Siemens PLM NX CAD/CAM software which started out as a CNC programming software back in the 1970's when it was owned and developed by McDonnell-Douglas was one of the first all in one design and programming software packages that was capable of 5-axis programming. It isn't cheap but it is pretty nice to use. If you have the software you get the Post Processor development kit that lets you build custom posts for any configuration of a machine you might want to build.
    Open Mind is another 5-axis software. It is designed for 5-axis free form surface machining.
  17. HC.Carbo
    HC.Carbo Journeyman
    little 500w spindle :)
    i'm not a guy that want to cut allu asap :D
    so far the best setup, next will be a more normal router h style (sorry for that :D )
    GrayUK likes this.
  18. Sprags
    Sprags Well-Known
    I have a 800w water cooled spindle 0-24000 RPM ER11 collet. My plan for this spindle is to machine aluminum. I don’t plan on heavy cuts.
    Obviously perhaps too heavy and too big for a 5 axis machine.
    #18 Sprags, Feb 23, 2018
  19. MStillman1966
    HC, really nice looking machine!
    i'm hoping you might be able to assist me in my journey.
    i have been making wooden fishing lures for the past 2 decades and they come along way.
    i put a router on a lathe and followed a template. I have been learning F360 and have been able to create some pretty shapes (at least in CAD).
    I have attached some target ideas.
    I would have the round or rectangle stock on your circular table (mounted at "tail of lure")
    My largest anticipated stocks would be @ 50mm x 50mm x 250mm - this would be extremely large
    A typical finished lure is about 125mm long x 25mm round(ish).
    Your pencil is pointing at the face of the lure, see the image with the "red splashing face") this is the top in my CAD file.
    I am assuming that the machine would be able to get the face and all sides and angles necessary to complete?
    How can we work towards making a machine that makes fishing lures?
    Can i send you a file to examine?
    I am very excited!!!
  20. MStillman1966
    more questions...
    Where did you source that super cool rotating table/slider/ system?
    can you share some details on the build??
  21. HC.Carbo
    HC.Carbo Journeyman
    interesting :)
    25cm height, this mean that the space between the a/b table & the spindle has to be +30cm
    so the lure goes horizontal to the spindle to cut the face.
    with this setup it would work i think (cbeam of 50cm = Z of 35cm)
    the table is just a cheap Chinese a/b table
    will come back to it when my machine is ready (printing the motor mount right now)
    follow it at https://openbuilds.com/builds/c_beam-x5l-hybrid_tank.6657/
    with this one i have a height of +-20cm
    check pocketnc tutorials how to program f360 for a machine like this :)
    note: still have to cut my first piece :)
