Hi! I have a Two Trees TTC 450 cnc mill that uses a DLC32 2.1 board and comes with a Z touch plate probe. I was wondering if I can upgrade that to the OB XYZ probe. This is the probe information according to the DLC32 manual: Pins: S G 5v Probe interface: When using CNC firmware, this interface can be used as a probe. When using the laser engraving machine firmware, this interface can be used as a flame detection function. The input signal voltage is 5V, the signal interface is S, and a 5V power supply interface is provided to supply power to the modules that need power supply.
Rad, Had the Same question.. Now for a “TTC 450” profile for set up wizard in the open-builds control software…
