Z probe not workin
Discussion in 'Control Software' started by Rob Atha, Oct 10, 2018.
  1. Rob Atha
    Rob Atha New
    :(hi all
    I’m after a bit of help. I’ve made a combined edge probe and touch plate for my cnc. Connected the positive to the plate and negative to my spindle. The positive is connected to port a5 on my Arduino Uno and ground to the ground pin. But no matter what I do, I can’t seam to get the probe to work, is there something I’ve missed as apart from how to use the probe, I can’t seam to find any tutorials on how to set it up.
    I’ve checked the continuity on the wiring and all if fine, but just won’t work then the tool touches the plate
    Hope someone can help with this:(:(:(:banghead:
  2. DarkPenguin
    DarkPenguin Well-Known
    Doesn't $H run the homing cycle?
  3. Rob Atha
    Rob Atha New
    I’ve managed to sort this now, it appears that the internal pull up resistor on my uno isn’t strong enough for my build
