Z probe and bcnc set up??
Discussion in 'CNC Mills/Routers' started by pitzerwm, Oct 18, 2016.
  1. pitzerwm
    pitzerwm New
    I have asked this over at Github and no answers, I have read everything and watched all of the videos and I still have a question. Bcnc appears to automate the probe function. In the wiki manual, it skips right over the Probe tab, and goes to Autolevel, which at this time, I don't need.
    See pix for the blank spaces that are there to help you get the z 0 set quickly.
    I have the plate, thickness 1.61 mm and wired in to the controller board. When I place the bit over the plate a few mm it lowers, touches and stops. Obviously, this isn't really z0, where do I tell the software that the plate thickness needs to be subtracted or added depending on your point of reference?
    Thanks for any help.
    What does TLO do ?
  3. David the swarfer
    Also, on the 'tool' tab there is a 'calibrate' box, I think that is where you put in the touch plate thickness
    Giarc likes this.
  4. OldDogSleeping
    you can type values into the WPOS boxes; so once the probe has completed, enter your plate thickness as the current Z Value.
    Alternatively you could use one of the user configurable buttons on the Control Screen and set it to run something like;
    G38.2 Z-3 F1
    G92 Z1.61
  5. Kyo
    Kyo Veteran
    @David the swarfer TLO is Tool Length Offset..
    A simple way would be to enter your plate thickness in tlo run your probe routine and then hit Z=0.. If you want to use probing often just set up a marco. Both options are discussed "Here"
    The Calibration option is used to find your plate thickness for tool changes vs the zero of your work. You can read about it "Here".
    I prefer the paper or feeler gauge method. Simple and quick. When I get around to trying a pcb I might have to look into probing / auto leveling more.
    #5 Kyo, Oct 19, 2016
  6. pitzerwm
    pitzerwm New
  7. wiremonkey
    I automate XYZ in UGS with a macro, 10 seconds, done:
    I broke down the gcode in the comments section for those that are learning, like myself.
    #7 wiremonkey, Jun 1, 2017
    Hisha, Mike Piechowski and Kyo like this.
  8. Thomas53
    Thomas53 New
    Sorry to say but I find this solution very devious . . . Give my solution a try and give me your opinion . . .
    1 take a micro switch and drill a ~3mm hole in the back . . .
    2 glue with 2comp epoxy the shaft of a broken cutter or dril in this hole . . .
    3 solder two wires to C and NO and connect them with your Probe Terminal.
    With this 50 cents tool you can Auto Level non conducting material.
    It will give you a precision/resolution better than 50 microns and also works top when you want to engrave.
    All letters and symbols will have exactly the same depth !
    Regards, Tom
    BEANTWOORDEN
