z-axis wierd kick backs
Discussion in 'CNC Mills/Routers' started by KasperV79, Mar 11, 2020.
  1. KasperV79
    KasperV79 New
    hi all.
    Can someone help my diagnose this issue.
    Its like my Z axis kicks back (see movie 9sec and 13 sec.) it loses several millimeters on every job. I can't get it to fail by jogging while I'm trying to pull it back, so it's not the load that s the problem.
    First it thought it was the cabling, so I changed all the cables to prober 4x0.35mm2 shielded cable. but thats havent solve anything.
    Here's the first part of the grbl code.
    Code:
    (Made in : Autodesk CAM Post Processor)
    (G Code optimized for OpenBuilds OX,Workbee,Sphinx,Lead with BlackBox GRBL V1.1 controller)
    (Program Name : 1001)
    (2 Operations in 1 files.)
    (File List:)
    (  1001.nc)
    (This is file: 1 of 1)
    (This file contains the following operations: )
    (1 : Pocket2)
    (  Work Coordinate System : G54)
    (  Tool  1: Flat End Mill 4 Flutes, Diam = 1.5mm, Len = 5.00mm)
    (  Spindle : RPM = 3000)
    (  Machining time : 5 min 21 sec)
    (2 : Drill2)
    (  Machining time : 15 sec)
    G90 G94
    G17
    G21
    (Operation 1 of 2 : Pocket2)
    G90
    G53 G0 Z-10
    G54
    S3000 M3
    G4 P1.8
    X18.691 Y24.497
    Z10
    X18.691 Y24.497
    X18.691 Y24.497 Z1.2
    G1 X18.691 Y24.497 Z-0.05 F50
    X18.685 Y24.487 Z-0.107
    X18.673 Y24.457 Z-0.156
    X18.667 Y24.409 Z-0.189
    X18.681 Y24.354 Z-0.2
    X18.726 Y24.256 F100
    X18.897 Y24.147
    X19.103 Y24.147
    X19.274 Y24.256
    X19.363 Y24.45
    X19.333 Y24.656
    X19.203 Y24.805
    X19 Y24.867
    X18.797 Y24.805
    X18.667 Y24.656
    X18.637 Y24.45
    X18.681 Y24.354
    X18.714 Y24.307 Z-0.189
    X18.754 Y24.28 Z-0.156
    X18.785 Y24.27 Z-0.107
    X18.796 Y24.268 Z-0.05
    G0 X18.796 Y24.268 Z5
    X18.691 Y24.497
    X18.691 Y24.497 Z1
    G1 X18.691 Y24.497 Z-0.25 F50
    X18.685 Y24.487 Z-0.307
    X18.673 Y24.457 Z-0.356
    X18.667 Y24.409 Z-0.389
    X18.681 Y24.354 Z-0.4
    X18.897 Y24.147
    X19.103 Y24.147
    X19.274 Y24.256
    X19.363 Y24.45
    X19.333 Y24.656
    X19.203 Y24.805
    X19 Y24.867
    X18.797 Y24.805
    X18.667 Y24.656
    X18.637 Y24.45
    X18.681 Y24.354
    X18.714 Y24.307 Z-0.389
    X18.754 Y24.28 Z-0.356
    X18.785 Y24.27 Z-0.307
    X18.796 Y24.268 Z-0.25
    X18.691 Y24.497
    X18.691 Y24.497 Z0.8
    G1 X18.691 Y24.497 Z-0.45 F50
    X18.685 Y24.487 Z-0.507
    X18.673 Y24.457 Z-0.556
    X18.667 Y24.409 Z-0.589
    X18.681 Y24.354 Z-0.6
    X18.897 Y24.147
    X19.103 Y24.147
    X19.274 Y24.256
    X19.363 Y24.45
    X19.333 Y24.656
    X19.203 Y24.805
    X19 Y24.867
    X18.797 Y24.805
    X18.667 Y24.656
    X18.637 Y24.45
    X18.681 Y24.354
    X18.714 Y24.307 Z-0.589
    X18.754 Y24.28 Z-0.556
    X18.785 Y24.27 Z-0.507
    X18.796 Y24.268 Z-0.45
    X18.691 Y24.497
    X18.691 Y24.497 Z0.6
    G1 X18.691 Y24.497 Z-0.65 F50
    X18.685 Y24.487 Z-0.707
    X18.673 Y24.457 Z-0.756
    X18.667 Y24.409 Z-0.789
    X18.681 Y24.354 Z-0.8
    X18.897 Y24.147
    X19.103 Y24.147
    X19.274 Y24.256
    X19.363 Y24.45
    X19.333 Y24.656
    X19.203 Y24.805
    X19 Y24.867
    X18.797 Y24.805
    X18.667 Y24.656
    X18.637 Y24.45
    X18.681 Y24.354
    X18.714 Y24.307 Z-0.789
    X18.754 Y24.28 Z-0.756
    X18.785 Y24.27 Z-0.707
    X18.796 Y24.268 Z-0.65
    X18.691 Y24.497
    X18.691 Y24.497 Z0.4
    G1 X18.691 Y24.497 Z-0.85 F50
    X18.685 Y24.487 Z-0.907
    X18.673 Y24.457 Z-0.956
    X18.667 Y24.409 Z-0.989
    X18.681 Y24.354 Z-1
    X18.897 Y24.147
    X19.103 Y24.147
    X19.274 Y24.256
    X19.363 Y24.45
    X19.333 Y24.656
    X19.203 Y24.805
    X19 Y24.867
  2. Gary Caruso
    Hi Kasper, Is your flex coupler set-screw tight onto the flat of the motor shaft?
    Gary
  3. KasperV79
    KasperV79 New
    yes, rock solid, cant twist it with my finger.
