Y axis Issue
Discussion in 'CNC Mills/Routers' started by John H, Sep 27, 2014.
  1. John H
    John H New
    I am just wiring a new build and cannot get the Y axis to work properly. Any motor plugged into that axis on the control board oscillates when given a + or - input. Can anyone help?
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Hi John,
    What control board are you using ??
    What control software are you using ??
    Tweakie.
  3. John H
    John H New
    It is a 4 Axis board that I bought through China. I have 4 270 in/oz motors that I am using. The software appears to be a version of Planet CNC (USBCNC4axis) software.
    I have not even gotten to the software yet. I am using the manual hand control to check + and - movements. A motor will operate fine when connected to either X,Z, or A axes. When connected to Y axis, the motor just oscillates.
  4. Tweakie
    Moderator
    You could try checking (with everything switched off) that you have your Y axis motor connected correctly – use a multimeter / continuity tester to identify the A-A and B-B windings of the motor.
    If that does not resolve the problem then contact the supplier of your equipment and see if they are willing to help (you have a 50/50 chance of getting their help).
    This perhaps highlights the typical problem (mentioned on the PlanetCNC and Warp9 websites) that purchasing cheaper copies / clones of their genuine product may leave the buyer without any proper technical support or backup if things go wrong.
    Tweakie.
