Hi everyone, hope you are doing great! I have finish my first ox cnc 1500x1500mm and wired it but i have problem with my y and x axis. It seams all is well wired, when turn each stepper with arduino + gshield off it lights on each axis. The problem is when i turn on the power supply and plug the usb to pc, then i open the grbl interface, it only moves wright the Z axis, when i jog the X and Y axis i see the light of both on and hear the motors noise but they don´t move. My setup is with arduino uno Rev 3 + gshield v5 running grbl Z axis - 1 nema 17 X axis - 2 nema 23 hightorque (only one runing for test then i will wired) Peak current is 3.0A/phase 12" Leads (4 Wire Bi-polar) Y axis - 1 nema 23 hightorque - the same as X axis Can you help me to discover this, i have tried to search this in forum and i didn´t found so i'm sorry if this isn´t the right place to ask. thank you. regards, Ricardo
