XYZ Touch Probe Plus And xPro v4
Discussion in 'Controller Boards' started by Bowbo974, Oct 7, 2020.
  1. Bowbo974
    Bowbo974 New
    Hi, i want buy a xyz touch probe plus.
    I would like to know if it is compatible with the cnc xpro v4 card?
    if it is compatible, what are the connections?
  3. ljvb
    ljvb Well-Known
    Any particular reason that the 5v is connected to the pin instead of the output 5v screw connector.. or can we... I only ask because I don't have the connector at the moment, but if it just needs a 5v supply, would that work.
    The 5v Output screw terminal you mention, isn't it the the 0-5v spindle analog output signal terminal? next to the 0-10v one?
    #4 Peter Van Der Walt, Oct 27, 2020
  5. ljvb
    ljvb Well-Known
    It is.. I just realized that that is analogue, and the one on the header is digital.. so ignore my last question. I'll just run it for now with sig and grnd
