XYZ Probe
Discussion in 'CNC Mills/Routers' started by John Ford, Apr 13, 2021.
Tags:
  1. John Ford
    John Ford New
    I have query about the XYZ Probe. My probe works okay but the LED lights are on all the time. This is not the case in your videos - the LEDs only come on when the bit comes in contact with the probe. Is this a wiring issue? Thanks
  3. gibson
    gibson Well-Known
    having same problem
  4. John Ford
    John Ford New
    Check your wiring and make sure all wires are secure and colours match the diagrams
  5. gibson
    gibson Well-Known
    i was just talking to jason and every thang is matched up lights are still on all the time
    thank you for reply.
    Tell us a little more about your setup. What controller, what spindle, anything non standard in your machine, etc.
    Always as in always, or, for example on when you clip the magnet to the collet.
  7. gibson
    gibson Well-Known
    I am using xpro v5 and openbuild controller with the xyz probe plus spindle 2.2kw water cooled vfw....
    Wired correctly? Any continuity between Earth and DC GND (should not be)
  9. gibson
    gibson Well-Known
    i watched video about 6 times wiring is correct
    You'd have to measure :) its about the VFD side of things usually. Check for continuity between EARTH and GND
  11. gibson
    gibson Well-Known
    VFD is hooked up separtly,,,, and I tryed grounding to other area as well it dose the same thang.
  12. Peter Van Der Walt
    Sorry not sure what you mean.
    As mentioned above:
    Take a Multimeter, and find where in your system, you are shorting DC GND to AC Earth. These should be seperate domains. Accidentally shorting them together results in the probe finding a path back to DC GND via AC Earth. Also. Very dangerous.
    See XYZ Probe Plus with VFDs and other ground-loop inducing components
    Or, replace the spindle with a double insulated router (Dewalt, Makita, RoutER11 etc) if you do not want to address the complicated VFD wiring
  13. gibson
    gibson Well-Known
    ok sir i did a test there are no broken wires on the xyz probe plus ,,but i took off the 2.2kw spindle and when Iend it agianst the machine it still light up now i did nother test and took it away from the machine rails and hooked the xyz probe magnet to the spindle no light but when i touched the probe to the bit it light up and unlight when i took it off.
  14. Peter Van Der Walt
    Yes, see above. Been saying the spindle is likely the short all day already :)
  15. gibson
    gibson Well-Known
    so is there any way to fix this or do i buy the er11 rotor lol would like to keep my spindle if there is a way to fix this
  16. Peter Van Der Walt
    1) use a multimeter or elimination strategy
    2) identify the miswiring or other cause of short circuit
    3) then fix that
  17. gibson
    gibson Well-Known
    humm ok
  18. gibson
    gibson Well-Known
    I guess i am getting the routorER11 BUT I NOTICED THEY ARE OUT OF STOCK LOL
  19. Peter Van Der Walt
  20. gibson
    gibson Well-Known
    ok heads up on the out come I narrowed it done to the X Y LIMIT SWITCHES they are touching the cnc frame so I have to find another way to attach them I just installed lien rails .
  21. gibson
    gibson Well-Known
    I figured it out it was the limit switches grounding me out making light stay on all the time now its working right .
  22. Peter Van Der Walt
    Good job
    gibson likes this.
