Xtreme Mini V Wheel™ Kit
Discussion in 'General Talk' started by efis, Sep 4, 2015.
  1. efis
    efis New
    I just got several sets of Xtreme Mini V Wheel™ Kit and when I tighten the assembly on a plate they do not turn freely. If I loosen the torque, then they turn but with uneven movement, if I loosen further the bolt is almost loose.
    Is this an indication of defective bearings?
    Has anyone had the same problem?
    Did you put the washer in middle of the wheels between the two sets of bearings?
  3. efis
    efis New
    That was problem, had not seen exploded view.
