XPRO
Discussion in 'Controller Boards' started by Gary Johnson, Jul 14, 2018.
  1. Gary Johnson
    Got a new xpro board and hooked up the stepper motors ,power supply ,everything.
    It had some pretty led lights on it ,but that was all of it.
    What software am I suppose to use for it .
  2. Gary Caruso
    Hi Gary,
    Lots of info here XPro Wiki
    It boils down to a few choices, Universal Gcode Sender (UGS) , GRBL Panel or Estlcam for actually interfacing with the machine.
    Your Computer will need Arduino drivers on it for the Xpro be be seen by it.
    Good luck
    Gary
    Links...
    Arduino Drivers
    UGS
    GRBL Panel
    Estlcam
  3. Gary Johnson
    Thank you Gary ,for the info. What one of them is the simplest to use.
    I am still old school . I was using Win.XP pro,Mach 3,SKP 7.
    The old driver boards finally stopped working.
  4. Gary Caruso
    Hi Gary, If you can configure Mach 3 things will look familiar.
    So is skp 7 = sketchup 7? is sketchup what you plan on using? SketchUCam?
    Then all you would need is UGS, i like the setup and visual preview on it.
    If you can do DXF drawings then Estlcam is very good, and many youtube videos showing how to use it.
    Gary
  5. Gary Johnson
    yes, i want to use sketchup . I use Inkscape to convert pdf to dxf .Then I can take the dxf file and put it in Skp.
    Long process to do that .
  6. Gary Johnson
    Sorry for stop .Sometimes my wifi cuts off.
