xpro V3 Ox built CNC: A-Axis does not work
Discussion in 'Controller Boards' started by Bernd, Dec 14, 2017.
  1. Bernd
    Bernd New
    xpro V3 Ox built CNC: A-Axis won’t work.
    Hello,
    i have a question regarding my CNC xpro V3 I am using with my OX-like built CNC router. It was running fine, until I have tried to change the stepper settings to a finer setting by moving the jumpers and Pot adjustment, because the Z-axis acted a bit sluggish.
    After the adjustment the A-axis, which is the designated slave axis to the Y-axis does not move at all anymore.
    The things I have tried:
    Changing GRBL settings,
    uploaded my initial GRBL settings again,
    Used different G-code senders,
    tried switching the stepper motors to check if it’s a motor problem.
    None of the above worked.
    Now I have measured the resistance between to connector pins at the board at the a-axis driver.
    There is no resistance between the A1, A2, B2, B1 connectors when the power is off, means , it seems like they have connection throughout.
    I guess the board is malfunctioning ?
    Any help appreciated.
    Thanks!
  2. lucascorato
    Not an answer to your doubt but... How do you make this Y slave thing? I built an upscaled version of the OX and the two Y motors don't seem to work well in series in this version, I might need more dedicated current to each motor separately.
    Thanks.
    lucascorato likes this.
  4. lucascorato
    Ok, I just found out that it spark concepts xpro v3 slaves Y by default!
