hello again, i have just received a new blackbox x32 unit today. absolutely nothing has been plugged in since opening this unit other than the usb supplied i have tried installing all drivers available, have tried 2 separate cables (the new cable i received and also the other blackbox v32 usb i have from the other unit, i have followed all guidance outlined in the troubleshooting section, could you please provide any information would be greatly appreciated, these re occurring issues have reduced me to tears and am seriously regretting embarking on this project [12:21:31] [ connect ] PORT INFO: Port is now open: /dev/tty.usbserial-0001 - Attempting to detect Controller... [12:21:31] [ connect ] Attempting to detect Controller (1): (Autoreset) [12:21:31] [ connect ] Attempting to detect Controller (2): (Ctrl+X) [12:21:32] [ connect ] Attempting to detect Controller (3): (others) [12:21:35] [ connect ] ERROR!: No Response from Controller - See docs:blackbox:faq-usb-connection-failed [OpenBuilds Documentation] for troubleshooting information. Closing port /dev/tty.usbserial-0001 [12:21:35] [ disconnect ] PORT INFO: Port closed Thank you in advance
No drivers installed, or that would have been SLAB_UART Checkout the BlackBox Documentation, section 4 (and the rest of the docs too, also full of important notes) docs:blackbox-x32:install-drivers [OpenBuilds Documentation] Make sure to read the Release notes inside the driver ZIP (Has specific instructions to deal with MacOS's restrictive nature)
