Hi guys! I'm building my first OX CNC, today I've started to wire electronics and straight away got stuck When I connect my XProV3 controller to Mac, I get next messages: Dropbox - Screenshot 2018-04-01 18.02.42.png These messages are cycled and xpro won't boot
there is oulput logs in ugs platform **** Connected to /dev/tty.usbserial-DN03VVBC @ 115200 baud **** Grbl 1.1f ['$' for help] >>> $$ $0 = 10 (Step pulse time, microseconds) $1 = 255 (Step idle delay, milliseconds) $2 = 0 (Step pulse invert, mask) $3 = 6 (Step direction invert, mask) $4 = 1 (Invert step enable pin, boolean) $5 = 0 (Invert limit pins, boolean) $6 = 0 (Invert probe pin, boolean) $10 = 1 (Status report options, mask) $11 = 0.020 (Junction deviation, millimeters) $12 = 0.002 (Arc tolerance, millimeters) $13 = 0 (Report in inches, boolean) $20 = 0 (Soft limits enable, boolean) $21 = 0 (Hard limits enable, boolean) $22 = 0 (Homing cycle enable, boolean) $23 = 1 (Homing direction invert, mask) $24 = 25.000 (Homing locate feed rate, mm/min) $25 = 500.000 (Homing search seek rate, mm/min) $26 = 250 (Homing switch debounce delay, milliseconds) $27 = 1.000 (Homing switch pull-off distance, millimeters) $30 = 1000 (Maximum spindle speed, RPM) $31 = 0 (Minimum spindle speed, RPM) $32 = 0 (Laser-mode enable, boolean) $100 = 26.667 (X-axis travel resolution, step/mm) $101 = 26.667 (Y-axis travel resolution, step/mm) $102 = 200.000 (Z-axis travel resolution, step/mm) $110 = 2500.000 (X-axis maximum rate, mm/min) $111 = 2500.000 (Y-axis maximum rate, mm/min) $112 = 2500.000 (Z-axis maximum rate, mm/min) $120 = 50.000 (X-axis acceleration, mm/sec^2) $121 = 50.000 (Y-axis acceleration, mm/sec^2) $122 = 50.000 (Z-axis acceleration, mm/sec^2) $130 = 320.000 (X-axis maximum travel, millimeters) $131 = 525.000 (Y-axis maximum travel, millimeters) $132 = 68.000 (Z-axis maximum travel, millimeters) ok >>> $G An error was detected while sending '$G': (error:2) Missing the expected G-code word value or numeric value format is not valid. Streaming has been paused. [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,100> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> Error while processing response <error:11>: Index: 0, Size: 0 [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:102,100,100> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:103,100,100> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:105,100,90> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:107,100,90> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> Error while processing response <error:11>: Index: 0, Size: 0 [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> Error while processing response <error:11>: Index: 0, Size: 0 [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> Error while processing response <error:1>: Index: 0, Size: 0 [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:107,100,90> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> Error while processing response <error:2>: Index: 0, Size: 0 [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:107,100,90> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:100,100,90> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0> [verbose] <Idle|MPos:0.000,0.000,0.000|FS:0,0>
by the way when i use serial monitor in arduino envirement i don't get ane errors an i can use $ and $$ commands nd change variables
Checked on Windows 10 It's working without any errors I've noticed in logs that UGS doesn't see java, might be it would help if I fix java problem
