X pro problems
Discussion in 'CNC Mills/Routers' started by allyn hughes, Oct 28, 2018.
  1. allyn hughes
    Hi all,
    I have a ox machine from ooznest running a x pro board, now the machine is only 3 weeks old and my x pro has just gone down for the second time. When I first power up the machine everything is fine but after around 5 mins the left Y motor goes down and the l.e.d on the board goes out. I spoke to ooznest who said it’s the board and sent me a new one out but now the new one has gone down. Has anyone got any ideas?
  2. Kevon Ritter
    Kevon Ritter Veteran
    Did you try swapping the steppers around?
  3. GrayUK
    Yes, try a process of elimination. Maybe get yourself a cheap Driver, to use externally, just to see if you can get a response that way. :)
  4. Rick 2.0
    Check for loose or bad connections between the stepper and the board as such connections may damage the board.
  5. allyn hughes
    Thanks everyone I will have a good look tomorrow and let you all know
