x pro help
Discussion in 'General Talk' started by JON D, Sep 7, 2015.
  1. JON D
    JON D New
    i received my x pro and wired up one of the motors for the x axis, downloaded the grbl controller 3.0 and tried to just move it manually but it wont let me open up a com port to connect with. is there a piece of software that i am missing or a step i missed? any help would be greatly appreciated.
    i am running windows '7 on a small notebook computer if that helps
  2. John Meikrantz
    John Meikrantz Well-Known
    1. You may need to download FTDI drivers.
    2. Don't use GRBL Controller. It has caused some xPro boards to "brick".
    From the xPro Build (http://openbuilds.org/builds/cnc-xpro-driver.643/):
    1) Please do not use GRBL Controller with the xPRO - we have 2 customers report issues with the xPROs being bricked - we are looking into this currently. As always our suggested program is Universal Gcode sender.
    2) the xPRO's V2 are shipping with GRBL 0.9g - this means the baud rate is now 115200 not 9600
    3) for some reason a few people have had issues with the drivers installing automatically on plug in. If this happens you can download the drivers from FTDI's website here -> http://www.ftdichip.com/Drivers/VCP.htm
    -- John (happy xPro user).
  3. JON D
    JON D New
    thank you for the direction but i am still unclear as to exactly which file to download for the driver on my computer its windows 7 32 bit
    also if i just install the universal g code sender do i even need this driver?
    thanks
  4. John Meikrantz
    Try installing universal gcode sender, and see if it can talk to the xpro.
    This is a link to an installer for the Windows drivers - setup executable
  5. John Meikrantz
    Added link to the stable 1.08 release of universal gcode sender:
    1.0.8
  6. JON D
    JON D New
    so i tried using universal g sender and no luck so i risked it with grbl and it seems to connect to the board. i connected my z axis and it makes a noise like its warming up when i open the port. but when i try to jog the z axis it doesn't move. the lights on the board light up when the code is sent. any ideas
  7. Ronald van Arkel
    Hello Jon,
    What motors are you using?
    What wiring and how is it wired?
    What PSU (Power Supply Unit)?
    Do you have your multimeter hooked up?
    Do you know how to adjust the driver (motor controller IC with its variable resistor)?
    Did you put the baud rate of the MoDem (serial port) at 115.200?
    Are you connecting to the right port?
    Did you install the USB to serial controller driver on your PC or is it showing a “?” at some of the devices in the device manager?
    What G-code do you use to move the axis?
    ... Might forgetting something here... :confused:
    It’s a bit guessing and all our crystal balls are not useful at all :blackeye:;).
    -Ronaldo_O
  8. Modesto
    Modesto New
    I am having the same problem as listed above. When I put together the CBeam Machine a month or two ago it was working fine with the GRBL controller. I didn't know not to use this one until now. The problem started when I installed the limit switches for homing the machine. It worked for a little bit and then the board stopped being recognized. I was using COM3 which does not show up anymore. I download the drivers from FTDI's website but it still doesn't work. Please see the photo of the board connected to the computer, all the lights are lit but it is unresponsive
    Does anyone have any ideas to help me?
    Thanks,
    Modesto
