X axis stalling mid command
Discussion in 'General Talk' started by TehBIGrat, Sep 22, 2018.
Tags:
  1. TehBIGrat
    TehBIGrat New
    Hi
    Am having a issue with the X axis on my GRBL CNC machine.
    Randomly the X axis stops moving at the end or start of a straight line.
    This only happens when running from gcode. Manually jogging does not cause an issue.
    It's not a slipping servo and I know it's not a skipped command because have of the command is done.
    change your X max speed to half what it is now, and change the X acceleration to half what it is now.
    if that cures it then you may have had them 'just too fast' or you have some binding in the X travel somewhere. remove the motor pulley and move the carriage by hand and you will probably feel the tight spot.
    I had this with my X, everything could travel ok at 7500mm/min EXCEPT at the far end of X, in the last 6 inches or so it would hesitate.
    now I run it at 3500mm/min and it is always happy.
  3. TehBIGrat
    TehBIGrat New
    Thanks for the reply. After much mucking around and changing things. We swapped the usb cable, haven't had a problem since. Will keep monitoring it and will try your suggestions next.
  4. TehBIGrat
    TehBIGrat New
    Further to this problem
    After 3 1.5mm passes this happens
