Would appreciate a laser module recommendation
Discussion in 'Laser Cutters' started by UniqueUserName2001, May 29, 2018.
  1. UniqueUserName2001
    Greetings.
    I just got my ARCO system and need a recommendation regarding the Opt PLH3D-2W laser. All I'm ever going to use the system for is burning artwork into plywood wood surfaces, logos n such on furniture.
    Will the Opt PLH3D-2W Laser be sufficient versus their PLH3D-6W-XF which seems popular with folks? There is a decent price difference I'd like to avoid if possible but willing to do it if necessary.
    Also, is the best thing to buy directly from them at? : CNC / 3D lasers - Opt Lasers
    Finally, it will be hooked up to the CNC xPRO v3 driver (CNC xPRO Controller V3) Anything else special I will need to connect (e.g adapters, kits, docking stations etc) and what wire gauge is recommended?
    Thanks for insight from anyone to help me finish this up and get it going.
    Regards,
    Craig
    PS apologies for double posting on the OpenBuilds ARCO system discussion before I figured out the forums.
