Workhorse 3D Printer
Discussion in '3D printers' started by shanehooper, May 26, 2019.
  1. shanehooper
    shanehooper published a new build:
    smithnovel likes this.
  2. jmnielsen
    jmnielsen New
    Impressive build. I've been looking through builds with fixed beds and a moving gantry, I'm sure this will inspire my own build!
  3. shanehooper
    Thanks! Let me know if you have any questions.
  4. Jonathan Schmidt
    Really excellent design and build, I especially like the choice of the high helix balls screws.
    Will you please tell me where you found those balls screws? I would like to try some like that in my build.
    Also the couplings look nice too.
    I see from your parts list, that you used acme screws for the Z-axis, was that to reduce cost or some other reason?
    I see that you have a well equipped machine shop.
    I wonder if you considered making a welded steel frame.
    At least for me, (because of the work I usually do) a welded steel frame seems less expensive and easier to make.
    About the bed, how are you heating such a large bed? Multiple heaters?
    Do you plan to print directly on aluminum or some kind of sheet?
    Do you feel any need to enclose it?
  5. Gregory Perry
    Good looking build. In the BOM there is reference to milled parts, are all of the parts on the BOM available via OpenBuilds or is there custom milling involved?
    Any thoughts on autoleveling (especially for a build size that large)? You'd probably want to go silicone heater + volcanic rock plate for that, 350x350mm is tough to heat!
  6. Muhamed Elshazly
    Im new
    Do you have the design in pdf to print it in papers? Workhorse Printer Assembly.step
  7. Lieme
    Lieme New
    Is this a printer with a heated bed or isn't it?
  8. David Bassetti
    FANTASTIC Machine..!!!! Congratulations.. it's a real beauty..!!
  9. Mark Carew
    Awesome build, with great print results! :thumbsup: Thank you for sharing
  10. Christian Joseph
    This is amazing!! Could you post the firmware for it please
  11. MalCNC
    MalCNC New
    Awesome build! Nice pitch on those lead screws I'll bet you can make this workhouse really fly. Have you thought about ballscrews? I've found the leads start to have backlash problems after running them for awhile... Just a thought. nice build
  12. shanehooper
    Thanks! The first build had ball screw. At the time we couldn't find a ball screw with a longer lead that was affordable and the machine was slow. So we went with multi start lead screw with a 50mm lead. We're starting to use anti backlash lead screw nuts now.
