Workbee Dual xPro v3
Discussion in 'CNC Mills/Routers' started by cahodk, Feb 5, 2019.
  1. cahodk
    cahodk New
    Hi. I have a Workbee with an xPro v3 that control x, y and z axis. I would like to make a modification, so that i might be able to control more motors - for a fourth axis or for extrusion.
    I control it via gcode.
    Is it possible to setup two xPros in a dual mode, and then send a gcode script to both of them?
    Best regards
    Carsten
  2. Alex Chambers
    You might be better off exploring what the duet controller can do for you. Talk to Oozenest about the possibilities. The cost of the duet seems to be about the same as the Xpro and it can be expanded with more stepper drivers.
  3. cahodk
    cahodk New
    Interesting. Ill check it out. Thanks.
