WorkBee CNC 1500x1500mm - Setup Help required.
Discussion in 'CNC Mills/Routers' started by Camvec, Mar 18, 2018.
  1. Camvec
    Camvec New
    Hello you wonderful people. So today was a great day, I've finally finished building my new WorkBee, I'm a total newbie to be honest and I'm on a very steep learning curve.
    So I'm using UGS, got it all set up as per the instructions, changes the $code settings too! And all jog controls work as they should.
    I press $H and it goes to all 3 limit switches and backs of 3mm. - great! So next I place it roughly centred on x/y set home zero point then I move it away and I can return to to home. Superb,
    MY QUESTION IS..... When I move the Y down to the bottom or X to the left it hits the plates. What have I done wrong? Should it just stop just before it hits the plates? I've set the correct $code on lines 131 & 132 (maximum travel) -200mm and -230mm less than my CNC size respectively as described in the manual. But still it wants to hit the sides.
    Can I just increase the 131/132 figure temporarily to see if it will not hit the side.
    Any help would be greatly appreciated so I can get going with my machine, thanks folks look forward to hearing your replies cheers Camvec (Scotland)
  2. T4Concepts
    T4Concepts Journeyman
    Hi Cameron,
    What are your 'Soft' and 'Hard' limits set to ? $20 may need to be set to '=1' if it's OFF ( =0 ). I may be wrong, but I think the 'Soft Limit' is a safeguard for the maximum travel set.
    This may help > gnea/grbl
    Let us know if this worked mate, as I'm still learning this stuff as well.
    TURK
  3. Vincent Walsarie
    Is it working correctly already?
    I’ve had the same thing, could it be that your limitswitches aren’t at the very end of the v slot beams?
    Otherwise I’d set $131&132 to say 500 and make sure it stops there..
    Still learning also... :)
  4. Vincent Walsarie
    What I’m facing with is the opposite, i get soft limit warnings of a 500x500 square on a 1000x1000 workbee
    Also my leadscrews are noisy video attached..
    #4 Vincent Walsarie, Apr 14, 2018
  5. GrayUK
    I think, as far as a set-ups go, you've got a pretty quiet one there. There is a little resonance causing vibration, but other than that, I can't really hear a problem. :)
  6. halfshavedyaks
    halfshavedyaks Well-Known
    really? is that really normal for the screw to get much louder for a bit partway through its travel? I haven't got a workbee yet, but If I heard that I'd be suspecting alignment issues or a bent screw.
