Workbee and Lead
Discussion in 'General Talk' started by Rink, Dec 10, 2020.
  1. Rink
    Rink Well-Known
    What is the difference between the Open Builds Workbee 1010 and the Open Builds Lead 1010?
    After reviewing the descriptions, I can’t tell. Both about same size. Both lead screw driven. I’m probably missing something simple.
    Thx, rink.
  2. Giarc
    The LEAD 1010 is a newer more modular system that does not need the larger gantry plates and uses less wheels. I believe it should have a larger cutting area as well because the gantry plates are smaller so the gantry can travel farther along the axis.
  3. DarkPenguin
    DarkPenguin Well-Known
    There is also a high z option for the lead. If you want such a thing for workbee you need to buy some aluminum and magic it up.
    LEAD is the "leader" of the pack (;
  5. Rink
    Rink Well-Known
    Ha! I’ll remember that.
    Giarc: thanks for the info. By the specs, it looks like the Workbee has slightly larger work area. But barely enough to notice.
    I have another question but will post another thread for that one.
    Thx, rink.
