WorkBee 1510 controler
Discussion in 'CNC Mills/Routers' started by KEITHABEAR, Sep 13, 2018.
  1. KEITHABEAR
    How hot is to hot for the controler
  2. Kevon Ritter
    Kevon Ritter Veteran
    PC electronics should not exceed 90C. With proper built in fail safes, they even begin throttling themselves. Above 100C begins to get into the range of irreversible damage. That's also boiling temperature.
    This isn't a PC, but they share the same components. If you can't indefinitely touch it, it's too hot. If it makes you feel uncomfortable, them it's too hot.
