WorkBee 1000mm X 1500mm Build Questions
Discussion in 'CNC Mills/Routers' started by KCollins, Apr 7, 2021.
  1. KCollins
    KCollins New
    Can someone tell me the dimensions of the attached image??? I'm starting with building a bench for this to sit on. The ooznest dimension says it is 1060mm X 1540mm. Are these correct?
