Got my first driver and stepper in the other day so I'm trying to get them wired up but I'm drawing a blank on this. I have a ST-M5045 driver http://www.sainsmart.com/zen/documents/20-019-209/ST-M5045 Instruction manual.pdf and a Sainsmart mach3 breakout board SainSmart 5 Axis Breakout Board for Stepper Motor Driver CNC Mill 3D Printing, Arduino, Robotics | Sainsmart The area i'm having trouble with is that the driver has 6 wire slots for the control board and I'm only seeing 4 per stepper on the controller. I think I'm supposed to connect EN -->ENA(-) DIR-->DIR(-) STEP-->(PUL(-) +5V-->? I'm assuming that all the negatives are common(COM?) ground? I'm not sure what the 5 volt positive is supposed to go to. Is VCC in the driver documentation+5V? EDIT: looked a bit closer at the driver diagram and realized that the controler connections connected to the negative end....and it looks like I'll need a 240 ohm resistor for 3 of the connections?
