Wires to big for Controller
Discussion in 'CNC Mills/Routers' started by eleethesontai, Mar 24, 2018.
  1. eleethesontai
    my stepper motors have 22 gauge wire and when I was testing them in my panucatt gradus m1 pro they worked and fit fine. however when I soldered the 18 awg/4c shielded wire to the steppers I found that the 18awg wire does not fit into the connectors on the gradus board. Is there some sort of an adapter / connector to accomplish this?
    after some research I did not find anything on google specifically but was thinking that one of these might work
    idea 1
    idea 2
    idea 3 - solder the wires to the end of a 4 wide pin header and plug the pin header directly into the screw terminal.
    #1 eleethesontai, Mar 24, 2018
