Will it Laser?
Discussion in 'General Talk' started by MaryD, Sep 15, 2017.
Tags:
  1. MaryD
    MaryD OpenBuilds Team
    We wanted to find out if Denim could be cut by the ACRO Laser. So we picked up some jeans and it worked!
    What should we try next?
  2. Jonathon Duerig
    Jonathon Duerig Journeyman
    Art board (engraving/cutting): Canson Mi-Teintes Board - BLICK art materials
    1/16" black acrylic (engraving/cutting)
    Neoprene-coated polyester (Is neoprene safe to cut? Is polyester safe to cut?)
    Try registration for combining routing and cutting/engraving. Use a C-Beam machine or OX to cut/engrave a sign. Leave an onion skin behind. Then use the laser to char the engraved out parts of the sign and then cut through the final onion skin. Cut out a contour map using a router. Then engrave/darken every other contour ring with a laser.
    -D
  3. Rick 2.0
    Dollar Tree Readi-Board.
    MaryD likes this.
  4. MaryD
    Sounds like you've got a project in mind ;)
  5. Jonathon Duerig
    Ah, you are completely mistaken, @MaryD. That list right there represents at least half a dozen projects! :)
    -D
    GrayUK and MaryD like this.
  6. stanley hardy
    Any chance it would be able to cut a 24 gauge plate of mild steel if you slow the feedrate down a lot?
  7. Joe Downard
  8. MaryD
    Here are some materials we've tried so far... Readi-Board is on deck.
    Denim
    Bamboo
    GrayUK likes this.
