Why are my Z Axis Steps per mm so high?
Discussion in 'Controller Boards' started by Geeksmithing, Jan 20, 2018.
  1. Geeksmithing
    Hi! I recently swapped out an arduino/Gshield for a Spark Concepts xPro.
    After this switch, I have to put in a very high value (1282) for steps per mm on the Z axis for to move the correct distance while calibrating. Is this indicative of a possibly bigger problem?
    The steps per mm for the X and Y axis are only 40 steps per mm. What could be causing this?
    Thanks!
    Here are the rest of my grbl settings:
    $0=10
    $1=255
    $2=0
    $3=6
    $4=1
    $5=0
    $6=0
    $10=1
    $11=0.020
    $12=0.002
    $13=0
    $20=0
    $21=0
    $22=0
    $23=1
    $24=25.000
    $25=500.000
    $26=250
    $27=1.000
    $30=255
    $31=0
    $32=1
    $100=40.000
    $101=40.000
    $102=1282.000
    $110=5000.000
    $111=5000.000
    $112=500.000
    $120=250.000
    $121=250.000
    $122=50.000
    $130=790.000
    $131=790.000
    $132=200.000​
    check the microstepping setting on the Z driver.
    what is the leadscrew pitch? you only need enough microstepps to give you 0.01mm per step.
  3. Giarc
    With an M8 with 1.25 pitch at 1/8 microstepping, 1280 is the steps/mm according to this RepRap Calculator - Prusa Printers But, I do not know if that is the screw you are using. It was just a guess since the math works.
    Are you using belts with a 20 tooth pulley at 1/8 microstepping on X and y?
  4. Chris Scholl
    Set your value to 400 steps per mm (using x16 microstepping/interpolation) for the T8 lead screws from openbuilds.
  5. David the swarfer
    You need to change the microstepping setting on the Z axis driver, it appears to be x8 which is giving this high value which is also EXCEEDING the GRBL max step rate
    Z (micro)steps per mm: 1280.000000 0.00078125mm per step
    Z max steps/s: 42666.666667 Greater than 30kHz!
    reduce to x4 and you can run happily at
    Z (micro)steps per mm: 640.000000 0.0015625mm per step
    Z max steps/s: 21333.333333
    but this may limit your max speed on Z, reducing the microstepping further to x2
    Z (micro)steps per mm: 320.000000 0.003125mm per step
    Z max steps/s: 10666.666667
    will allow a higher max speed while retaining pretty good resolution.
    in other words, on the board you see this
    and you need to move the uSTEP jumper
    jumper settings at Spark-Concepts/xPRO
    turn everything off before changing the jumpers
