Which build plate for 500x500mm printer
Discussion in '3D printers' started by Hesus, Mar 12, 2020.
Tags:
  1. Hesus
    Hesus New
    Hi. So I'm building a 3d printer based on rat rig v-core v2 500x500x500mm core xy build volume with bed frame 529x529mm and 4mm aluminium bed. Now i need something to put on bed but i can't find something good and i need some help from you guys.
    Buildtak is expensive like hell.
    I can't find borosilicate glass in my Country in that size.
    I found a glossy carbon plate but its around 250 euro.
    I thought about prima creator flex plate 510x510 with a thin pei sheet but I'm worry about durability of pei sheets.
  2. Troy Proffitt
    Troy Proffitt Well-Known
    I'm building something similar and I'll be using a piece of tempered glass. I use one on a printer that has a 400x400mm printer now and it works great.
  3. Hesus
    Hesus New
    Sorry but seen to many broken tempered glass beds. But actually i found a robax/neoceram glass for firepits and i think this would be great. Its pretty cheap for 529mm x 529mm x 4mm plate.
  4. Troy Proffitt
    If you are breaking tempered glass, you are doing something horribly wrong.
    Rado Korpa likes this.
  5. Hesus
    Hesus New
    Tempered glass is breaking when you heating it to fast and i want a ~1500W 230V bed heater so its a little risky.
