When the job is finished...
Discussion in 'CNC Mills/Routers' started by leversole, Nov 27, 2015.
  1. leversole
    leversole New
    Using tinyG and chilipeppr...is there a way to make chilipeppr move the router out of the way when a job finishes? I could manually edit each GCode file and add a final move, just wondering if there is an automated way...what do others do?
  2. leversole
    leversole New
    May have figured this one out...Probably the way to go is to use your CAM software...I use CAMBAM, and there is a MOP (machine operation) footer where I can "auto" insert a final move command or anything else that I want, turn the spindle off, stop vacuum, etc.
  3. Joe Santarsiero
    Joe Santarsiero OB addict
    G28 and G30 are machine home commands.
  4. leversole
    leversole New
    Thanks Joe...I ended up adding
    G1 Z-0.5
    G1 X10 Y10
    Gets the spindle out of the way!
  5. Joe Santarsiero
    Well, it's a good thing you're inserting your own lines. ;) G-code is really quite friendly when get the chance to talk to it.
  6. David the swarfer
    why is Z negative? negative Z is normally 'cutting into the work'!
    note that in SketchUcam there are settings for doing this automatically. 'Use_Home_Height' and 'Use_End_Position' allow you to see a Z level and an XY position to go to at the end of the job.
  7. leversole
    leversole New
    Ha! Dont know why I typed negative Z! I used positive....but, come to find out, not an elegant solution, as if I have several operations on teh same part, CamBam puts the footer in each operation! Learning more and more GCode, pretty straightforward, as I develop permanent fiels, I will add any codes I need...
    Thanks ALL
