Wheel spacing
Discussion in 'General Talk' started by Adam Filipowicz, Sep 17, 2015.
  1. Adam Filipowicz
    Adam Filipowicz Journeyman
    If i was making a custom plate. to mount wheels for a 60mm vslot
    what distance above and below the vslot is the centre of the hole?
    eg. 10mm above/below extrusion is centre of hole for the regular wheel.
    The official position is section depth + 19.8 mm for the center to center distance of the bolt holes. In the real world however I find the distance on completed assemblies measures up to section depth + 20.3 mm.
    (... and personally, I just use section depth + 20 mm because it is so much easier.)
