What's best way to cut 8mm leadscrew?
Discussion in 'General Talk' started by Scott_, Oct 22, 2015.
  1. Scott_
    Scott_ New
    I'm thinking there must be a blade for my compound mitre saw, but is that the way to go?
    These are best cut with abrasive cutting wheels or with a common hack saw. I typically use a Dremel with a metal cutting disk or a grinder with a thin abrasive disk. The compound mitre saw would probably be the last thing I'd try.
  3. Scott_
    Scott_ New
    Thanks, makes total sense. Any suggestions for how best to cut the aluminum extrusion?
  4. Rick 2.0
    Miter saw with a high tooth count non-ferrous metal cutting blade. There's a whole post on the subject somewhere here in the forum.
  5. Scott_
    Scott_ New
    Thank you, I really appreciate your help!
  6. Adam Filipowicz
    Adam Filipowicz Journeyman
    Cold Saw if you got the coin :)
