What Stepper driver and power supply are needed??
Discussion in 'General Talk' started by Agung Dwi susilo, Jul 26, 2018.
  1. Agung Dwi susilo
    i have bought 4x stepper motor with 4.4 A.
    What stepper motor driver's is match and fit with this stepper motor ??
    and what kind of power supply specifications are needed ?? Screenshot_20180727-084038.png
    Would probably go 36V on the power supply and DQ542MA Stepper Motor Driver for the driver. That driver will leave the stepper motor just slightly under powered as it only provides 4.2A but the difference probably won't be noticeable. If you want a driver that will absolutely provide the full power I would suggest this model. Just be careful that you don't set the driver higher than what the motor desires as it could damage the motor.
    Agung Dwi susilo likes this.
  3. Agung Dwi susilo
    Thanks for explaining sir.
    And plan i will build cnc frame with 30x60 aluminium extrusion, whether v wheel will fit with that aluminium extrusion ??
    and we know the distance of 20x20 aluminum bulkhead is 6,3 mm.
  4. Rick 2.0
    Even if it does fit it will not likely wear well. The magic of the OpenBuilds V-slot is the beveled edges along the slot in the extrusion. This allows full contact of the beveled edges of the wheels against the extrusion and thus provides good wear characteristics. In that you'll only have very limited bearing on the pointed edges of the 30x60 extrusion probably won't lead to durable results.
    If this is a case of you already having the 30x60 extrusions and wanting to put them to good use consider using them as the main supports with smaller 20x20 or 20x40 sections of V-slot attached to the face as the glide surface.
  5. Agung Dwi susilo
    Thanks sir.
    I will build 1000x1000mm framework. If use 2040 does it can cutting aluminium plate sir ??
  6. Rick 2.0
    On its own, probably not. If that's all you can get though consider mounting it to the face of a larger, stiffer framework. Such a framework can easily be built from either aluminum extrusion or tubing. And to be clear, the 20x40 needs to be V-slot extrusion not ordinary 20x40 t-slot extrusion. The V-wheels don't work properly with ordinary t-slot.
  7. Agung Dwi susilo
    Thank you very much for explaining sir.
    I will come back after i build. you have solved my problem.
    may I ask you back later sir?
  8. Rick 2.0
    Not a problem, drop in any time. And please keep us updated on your progress.
  9. Agung Dwi susilo
    About GRBL sir,
    I have seen many tutorials on how to use GRBL.
    I saw someone using XLoader to upload hex files into Arduino.
    and some do not, i mean directly using the existing tools in arduino.
    what is the real difference between the two ways sir?
  10. Rick 2.0
    Sorry not an expert in that area. Maybe someone else will chime in. If not there's always the wiki. gnea/grbl
  11. Agung Dwi susilo
    Okay sir. Thank you. I will post my question problem in forum
  12. Agung Dwi susilo
    Sir, What will happen if i use power supply 36V 10A. Whereas i using 4x nema23 4.4A.
    In my mind ,if use 4 stepper motor is 4.4A x 4 = 17.6A current will need. But another reason its to expensive cost for me.
    I mean .the point is the use of Current sir.
    Will it work well with 10A??
  13. Rick 2.0
  14. Agung Dwi susilo
    Thank you very much sir. To share the link information.
    The best
