What small CNC mill should I build?
Discussion in 'CNC Mills/Routers' started by ClarkS, Feb 2, 2018.
  1. ClarkS
    ClarkS New
    Hello
    I'm a retired electrical engineer with experience in industrial control systems and programming, but no experience in machining. I want to build a small CNC that can do the following things:
    1. Help me learn about CNC on plastic, aluminum and maybe brass.
    2. Printed circuit board manufacturing
    3. Finishing of 80% AR lowers
    What mills would you recommend for this?
    Clark
  2. ClarkS
    ClarkS New
    No one has any recommendations for a first CNC mill?
  3. Scotty Orr
    Scotty Orr Journeyman
    There may be no one here with experience in all of those areas. I don't, so I can't make a recommendation.
  4. ClarkS
    ClarkS New
    That makes sense. I think the 3rd item might require a larger mill. I was hoping it could be done with a mini-mill, but maybe not.
    Suppose I eliminate that requirement...
    Does anyone have any thoughts about a good mill for learning and to make PCBs?
  5. Scotty Orr
  6. Giarc
    The Cbeam XL will probably work well for what you need. Or even the Cbeam. The kits are on sale with free shipping today.
