What length spacers for Nema 17 linear actuator
Discussion in 'General Talk' started by Jason Kraft, Jan 19, 2016.
  1. Jason Kraft
    In the Nema 17 linear actuator bundle, the aluminum spacer used is 40mm long. This in conjunction with a 45mm M3 screw leaves about 1-2mm of available thread to hold the motor in place (which seems quite small for something that will move and vibrate about).
    Was this a typo in the part store, and should I go with a 35mm spacer instead?
    This seems a bit odd as they used to recommend the 1.5" spacers which are a perfect fit. Even the M3 cap head screw page says they go with the 1.5" spacers.
    Jason Kraft likes this.
  3. Jason Kraft
    Ah so I wasn't going crazy :D that's good.
