What length M5 screws to attach "Mini V Linear Actuator Kit" to each other and or a "v-slot" rail
Discussion in 'General Talk' started by Richard Allen, Sep 6, 2018.
  1. Richard Allen
    Hi,
    I want to attach 3 x "Mini V Linear Actuator Kits" to each other using the end plates. I also want to attach two of them to v-slot 20 x 40 rail. What length of M5 screws should I use to attach the "Mini V" to the rail using "t-nuts" and to each other? Do I use separate M5 hex nuts when bolting the "Mini V"s to each other?
    Thanks for your help.
    Richard
  2. Mark Carew
    Hello @Richard Allen
    You can attach them to each other and to V-Slot using the Double Tee Nuts and 6mm Low Profile Screws
    The double tee nuts keep it nice and low profile as well as adds a little bit of a strong back bone to the bent metal casing so this works out really well.
    Here are a couple example pics that may help
    GrayUK and Richard Allen like this.
  3. Richard Allen
    Hi, thanks for the confirmation and pictures! Super helpful!
  4. Mark Carew
    You got it brother, glad to help
