what kind of aluminum can c-beam cut?
Discussion in 'CNC Mills/Routers' started by Elhanan, Nov 27, 2016.
  1. Elhanan
    Elhanan New
    can it be used to cut this sort of plates?
    at what thickness?
    The photo is not visible as you have linked to password protected content. Try dragging the photo into the edit box instead of linking. Thx.
  3. Elhanan
    Elhanan New
  4. Ronald van Arkel
    Looks like gauge 14 / ~2mm, should be easy in a few passes or when using trochoidal cutting you might do it in one pass. Just upgrade the 3mm gantry plate to a XL C-Beam plate and it should be okay to use the stock C-Beam machine.
    -Ronald
  5. Elhanan
    Elhanan New
    actually those are 12" , and if i'd like 10 gauge?
  6. Rick 2.0
    6061 is probably the most commonly used (among forum members) because of its easy machinability. As far as thickness, pretty much any thickness is possible as you are taking it away in small bites. Thicker just takes more passes. Just be sure and keep the chips cleared as you go.
    For a better explanation on aluminum types and their workability there are plenty of websites out there with good information including Onlinemetals.
    Edit: oops I see I was typing too slow... and Ronald got back first :blackeye:
    GrayUK likes this.
